Author Topic: Halloween Witch  (Read 19098 times)
Re: Halloween Witch
« Reply #9 on: September 06, 2013, 08:59:29 PM »
Thanks Jerry!
gerry Larkin
Re: Halloween Witch
« Reply #8 on: September 06, 2013, 01:10:27 PM »
Very Nice Indeed Glen!! 8)  Gerry.
Re: Halloween Witch
« Reply #7 on: September 05, 2013, 09:00:33 PM »
Ken, PJ - thanks! Already planning another one using the same figure. Not gonna spoil the surprise, tho'.
Re: Halloween Witch
« Reply #6 on: September 05, 2013, 01:16:54 PM »
Very nice work, Glen. A stunning conversion and paint-up!
mil-mart
Re: Halloween Witch
« Reply #5 on: September 05, 2013, 04:11:13 AM »
Glen excellent work on the conversion and painting and I too like the addition and expression of the Pumpkin. :)
Cheers Ken
Re: Halloween Witch
« Reply #4 on: September 04, 2013, 12:45:31 PM »
Thanks Nick. I've been studying the paintings of various pin-up artists and trying to get a feel for their techniques, then translating the oil painting techniques to modern acrylics. It forces me to up my game. I do like the way this one turned out compared to my previous efforts. Still pushing, tho'.
Re: Halloween Witch
« Reply #3 on: September 03, 2013, 05:28:34 PM »
Nicely done Glen, the see-through effect is excellent.
Adding the pumpkin really makes the whole piece pop.
Re: Halloween Witch
« Reply #2 on: September 03, 2013, 05:05:30 PM »
OK mods, what's up? I've tried to standardize the font (TNR) and size (12 pt) five times now, but it keeps coming up with different type faces and sizes.
Halloween Witch
« Reply #1 on: September 03, 2013, 04:54:58 PM »
This is another conversion of the Historex Pinup flat #NPLAT02 (my first, 'Santa's Helper', is on the old site). The figure is based on the 1962 painting 'Thinking of You'  by American pin-up artist Gil Elvgren. The piece was sculpted by Yvan Durand,  cast in resin, and appears to be around 120mm - maybe more.
The conversion was fairly straightforward - sheet plastic was used for the hat base, then putty was added to build it up. The hat band and buckle were scribed in. Putty was also used for the stocking tops, while the garters are .010" sheet plastic. The shoes were converted to boots with putty tops. Again, the boot strap and buckle were scribed in. I also filled in the mouth (it was crooked and gave the appearance of a smirk) and rescribed it at a slightly larger size. The pumpkin was cut out of .015" plastic, puttied, the sculpted out. The idea was to create a pumpkin that was looking up in a bit of awe - perhaps due to her physical attributes...
The piece was primed with Floquil Model Railroad gray primer cut about 25% with lacquer thinner. I let it gas out for 24 hours before painting the figure with Reaper acrylic paints.
 http://www.reapermini.com/Paints/corecolors
The basic skin tones are a 1:1 mix of the Tanned and Rosy skin triads - that is 1:1 Tanned Skin and Rosy Skin for the base, Tanned Shadow/Rosy Shadow for the shade, and Tanned Highlight/Rosy Highlight for the lights. Darker shading was accomplished using Burgundy Wine (not too much or the color goes purple). Lighter shading was made by adding Pure White to the highlight mix. The skin under the sheer nightie was a bit different in that it was the base skin shade, but with a little Stone Gray added. The idea being that the sheer black material would subdue the skin's pink tones and cast its own shadows. The skin under the nightie was painted first, then the nightie itself with a thinned mix of Stormy Gray and Pure Black to give a very dark gray. Pure Black was used where the material would be more opaque (such as folds). Stormy Gray was used for highlighting. The stocking covered portions of the legs received a similar treatment, but I warmed up the Pure Black with Blackened Brown. Or darkened the Brown with Black... The boots and hat were were painted with an opaque mix of the black/gray. Shading was done with a glaze of Black, while Cloudy Gray and Misty Gray were used to build up the highlights. The buckles have a Shadowed Steel base with a Honed Steel highlight and a Polished Silver final highlight. The hair is the Amber Gold triad with some Earth Brown and Pure White thrown in for final shading and highlighting.
The pumpkin is various combinations of Harvest Brown, Orange Brown, and Burnt Orange. A bit of Sun Yellow was added as a final highlight. The stem is the Olive Green triad as are the movement lines. The lines were painted directly on the black felt background. Boing!
Questions and comments are welcomed.
« Last Edit: September 03, 2013, 05:23:40 PM by marko92 »
