Author Topic: Access to past numbers of Journal on line  (Read 88889 times)
0 Members and 20 Guests are viewing this topic.
Re: Access to past numbers of Journal on line
« Reply #8 on: September 11, 2019, 09:22:51 AM »
You are all set Ric, you should now see another area of the site for Members and the BFFS Journal link on the top menu bar will now allow you to read/download Journals.  Enjoy!
« Reply #7 on: September 11, 2019, 06:19:25 AM »
I can confirm you are now a full member
Ed
Ric
« Reply #6 on: September 11, 2019, 05:31:43 AM »
I have no access to the online journal. Would you so kind to check my status of member. Thank so much.
Ric
« Reply #5 on: June 12, 2013, 09:45:05 AM »
Wolfgang you are set as well.
« Reply #4 on: June 12, 2013, 04:16:31 AM »
I have the same question. Would you be so kind to check my account, too?
many thanks
« Reply #3 on: June 11, 2013, 09:40:42 PM »
Eric sent you a note online.  Your account is corrected.
« Reply #2 on: June 11, 2013, 02:25:10 PM »
Welcome Eric!  You are doing nothing wrong in this case - I just need to double check your membership status and change your account to Member.  I will do that this afternoon and send you a Message when it is done.
For others, when you initially join the Site you are set up as an Associate which gives you the ability to view all of the Galleries, pictures etc as well as participate in the general boards.  This is more than fine and there is tons of content here for all of these folks who are welcome to join in and participate.
However, if you choose to sign up as a Member which has a fee involved and pay through PayPal your status is changed to Member and you have access to some other content most particularly the Journal - all 109 of which are all online.  This is all automatic if you join online, i.e. PayPal is linked from the site etc.
If you have joined through the mail I need to make the change manually which only takes a moment.  If others are in in Eric's situation, a Member whose status is not reflected here then just let me know and I will fix it.
Again welcome Eric I will send you a note a bit later.
« Reply #1 on: June 11, 2013, 12:27:59 PM »
Mark, I've logged in with my details byt, unfortunately, I don't seem to be able to access the members only sections such as the back numbers of the journal and the members list.
What have I done wrong?
Eric Gruber von  Arni
