Author Topic: Priming  (Read 7533 times)
Re: Priming
« Reply #8 on: May 23, 2013, 01:54:48 PM »
I use Games Workshop gray.
subsequently turpentine oil patina for the contours.
Re: Priming
« Reply #7 on: May 23, 2013, 01:42:37 PM »
I brush on Tamiya white.
Re: Priming
« Reply #6 on: May 23, 2013, 11:06:42 AM »
I generally use Floquil model railroad gray primer applied with a brush for metal and resin figures. For female figures I seem to be moving to fine white primers from a spray can or airbrush) the can is more convenient). For degreasing I use dishsoap and warm water. If there's a lot of grease (rare), I use Simple Green or Purple Power (I keep it in the garage for use on the MGs).
gerry Larkin
Re: Priming
« Reply #5 on: May 22, 2013, 05:18:38 PM »
I Use Both spray can and brush , on a larger flat  Carrs Acidip to start with, than Gw white in a spray can,
on a smaller flat Humbrol white all the way, better control and you dont clog details if you put on several thin coats, BTW carrs  Acidip is not an acid :) its a really great degreaser for white metal or resin, you can find from model railway suppliers, and it does what the distilled vinegar does  a lot quicker!  hope that helps.....  Gerry.
Re: Priming
« Reply #4 on: May 22, 2013, 03:22:16 PM »
Spray can!!!! A much smoother finish, and a pure White undercoat, no metal showing through on my figures!!  :o ;D  ;D
robboxxx
Re: Priming
« Reply #3 on: May 22, 2013, 03:04:00 PM »
hi nick
from a spray can or by brush?
Re: Priming
« Reply #2 on: May 22, 2013, 02:20:53 PM »
After a good vinegar bath, ( my figures, not me!!!! ;D ;D ;D ) I use Games Workshop Chaos White. ;)
robboxxx
Priming
« Reply #1 on: May 22, 2013, 02:02:32 PM »
Hi All
Just curious: what kind of undercoating (primer) you use?
