Author Topic: SEVRES 2018  (Read 4275 times)
Re: SEVRES 2018
« Reply #13 on: December 16, 2018, 04:39:27 PM »
The photos are great!  Thanks for all your work.
Re: SEVRES 2018
« Reply #12 on: December 15, 2018, 11:51:04 AM »
All pictures are loaded!
SEVRES 2018
« Reply #11 on: December 10, 2018, 06:58:33 AM »
Sèvres 2018, a succès again, but some 950 pièces were displayed at the contest, a bit less than 2017, and the crowd was also less than last year, perhaps the effect of the 'gilets jaunes' in the streets and on the Champs Elysées ...
As far as flats:   91 flats exposed by 42 artists  (9% of the pièces) against 128 pièces and 51 artists in 2017 (-29%):
   Dioramas:   4 dios by 2 artists
   Creation:     2 flats by 2 artists
   Masters:    36 by 20 painters
   Confirmed:  25 flats by 12 painters
   Novices:    24 flats by 7 painters
Awards:  9 Gold, 12 Silver and 14 Bronze - no award: 8 - no BoS
Jupiter Miniatures was present as vendor of flats ....
Some 130 pictures selected among 600 are under loading in the Show Gallery: http://www.intflatfigures.org/index.php?action=gallery;cat=230
message will be given when completed ....
« Last Edit: December 15, 2018, 04:15:39 PM by Hannibal »
Re: SEVRES 2018
« Reply #10 on: December 06, 2018, 04:26:17 PM »
Amazing!  Looks like magic to me. Thanks Michel.
Re: SEVRES 2018
« Reply #9 on: December 05, 2018, 02:11:11 PM »
Thanks PJ, one example from Jan_Paul
left:      his picture
center:  main reflections taken away
right:     small réflexions, remastering of foot of one couple (left down), adjust red colour, darken bblackbackgrond, reformat the outer red background equally alla round, and adjust the size and contrast.
Re: SEVRES 2018
« Reply #8 on: December 05, 2018, 02:04:55 PM »
I and the committee know how much work Michel go's too give us the show photos and it is greatly appreciated by us all  :)
As Pat said a big thank you!! to all who post show photos on this site
Re: SEVRES 2018
« Reply #7 on: December 05, 2018, 10:23:14 AM »
Wow, Michel! I never realized all the work you have to do to put high quality photos on our site. THANK YOU so much!
Re: SEVRES 2018
« Reply #6 on: December 05, 2018, 05:22:28 AM »
Super !! Thank you Jean Paul !!!
Indeed the gallery was asked before the week-end, and I am collecting pictures from myself (350), and four other sources, you will be the fifth source; (source is always indicated in the description of each picture)!
I have manually transcribed all the painters and flats names transcribed with Alain Chatenay, from the organizer committee on Sunday afternoon in their battle room ! Thank you to alain and Pierre S. ! for yor wonderful help and friendship!  A list is then established at home, by category and whenever useful, detals or other view or zooming, a chronological n ID number is assigned, in sequence of loading.
Then I rename and sort all pictures by flat and I then select the best picture available for each flat,
Then I remaster it (get rid of dusts, spots, adjust background, contrast, alignment, contrast (Under/over exposed, adjust the size, smooth the background, remove the contest white tag, retify the view to a rectangular view frm the front, ....) then standardize the size in pixels (too large is not readable and longer to load, very small, not readable)
Then I prepare the comments (description, author, size, editor, engravor, award, source, editor's name of the flat for search function among painters, ...)
Then I load then in the preset sequence, or, as you might have seen, I load the sequence blank, then add the pictures later as they are finalized, in their preset box ....
Now I will start the two weeks work, many hours, to get the best of these 600 pictures, in some 115-120 pictures as done for each other contests.  Please leave me one week more to start posting;
I will load them as general room/activity; creation/ masters / confirmed / novice levels / vendors / clubs (if pictures are available)
I can't do this when not attending myself as I don't have pictures of all flats, ignore the levels and names unless already posted, and there are less pictures ...
Next show will be Ransart, but some show in Spain in December might be open when getting access to some pictures.
Re: SEVRES 2018
« Reply #5 on: December 04, 2018, 05:19:37 PM »
Quite a lot of talent represented here with some beautiful work - thank you for sharing!
I just opened a Gallery for this Show that Michel requested as well.  He has a a large number of pictures he will be adding shortly.
Jean_Paul
Re: SEVRES 2018
« Reply #4 on: December 04, 2018, 04:06:02 PM »
Last
Jean_Paul
Re: SEVRES 2018
« Reply #3 on: December 04, 2018, 04:04:21 PM »
Part three
Jean_Paul
Re: SEVRES 2018
« Reply #2 on: December 04, 2018, 04:02:31 PM »
Part two
Jean_Paul
SEVRES 2018
« Reply #1 on: December 04, 2018, 04:00:38 PM »
This week-end at Sevres
JP
