Poll
What size will your next flat figure be ?
30mm
10 (58.8%)
45mm
2 (11.8%)
54mm plus
5 (29.4%)
Bust
0 (0%)
Resin
0 (0%)
Total Members Voted: 17
Voting closed: June 09, 2017, 04:11:21 AM
Author Topic: 30mm or bigger?  (Read 3925 times)
Re: 30mm or bigger?
« Reply #9 on: June 09, 2017, 12:51:38 PM »
It is good to see the 30mm still has a place with us, we will have to show more in comps and at shows  ;)
aba
Re: 30mm or bigger?
« Reply #8 on: June 03, 2017, 02:41:40 PM »
Dear all,
well as for the sizes one must take into account there are more than 100.000 different flats of 30mm (incl. 28mm) scale but to my rough estimate only 3 to 5000 flats of other scales, i.e. 20mm and larger than 30mm oday existing.
@willie :
I also like 28mm war games figures lookout flat makers they produce some nice ones and in lots of periods. I started out with  Britain's  my grandmother got me hooked.
As for these I own some, mostly Perrys (retreat of 1812). But these are - except some Perry and others - to much out of scale (i.e. proportionally disabled  :) ). But as these are of same scale of 30mm flats (1/56) there are very nice buildings and carts and very detailed artillery etc. existing. In fact I have edited one coach, a "chaise de poste" to match the napoleonic post set of Thiel.
I attach a photo of it. The flats have been painted by Eric Talmant and the house in the background is from Hudson Allen.
« Last Edit: June 03, 2017, 07:06:26 PM by marko »
Re: 30mm or bigger?
« Reply #7 on: June 03, 2017, 06:49:27 AM »
I am on a 75mm quadriconcept, then will go for a bust, and a 30mm in parallel
Actually I am painting flats since 2013, the ratio  30 mm/larger sizes( incl. busts) is around 3:1, and I believe both are very pleasant to paint and necessary.
Re: 30mm or bigger?
« Reply #6 on: June 03, 2017, 06:40:36 AM »
This is good to see ;)
Gerald
Re: 30mm or bigger?
« Reply #5 on: June 02, 2017, 11:59:01 PM »
Hm the next figures which I will be engraved will be three 30mm figures and a 50mm .... but painting I will probably a 75 mm figure.
Re: 30mm or bigger?
« Reply #4 on: June 02, 2017, 04:11:26 PM »
@Brian, your voting possibilities are too limited:
My next figure will be either 30 mm or 45 mm,
I like them both.
Mike G
  • Mike
Re: 30mm or bigger?
« Reply #3 on: June 02, 2017, 10:27:42 AM »
I only do 30mm although at some point I would like to try my hand at something bigger
New York
Re: 30mm or bigger?
« Reply #2 on: June 02, 2017, 10:23:57 AM »
Brain.  I like the 30s and have a lot to paint. I also like 28mm war games figures :o  lookout flat makers they produce some nice ones and in lots of periods. I started out with  Britain's  my grandmother got me hooked :o  I have a lot of 54mm from the old days and well get around to painting them.  ::)  I say this what scale you are happy with then paint it.  ??? Willie
30mm or bigger?
« Reply #1 on: June 02, 2017, 04:11:21 AM »
Following on from another thread  "All Lost" have you a preferred scale.
Is the 30mm figure loosing ground to the bigger figures that are now widely available?
