Author Topic: Sagebrush Tree Construction  (Read 4804 times)
nmrocks
Re: Sagebrush Tree Construction
« Reply #10 on: February 08, 2014, 12:31:49 AM »
Wow! Wolfgang, Very impressive diorama, the trees really make the scene come alive, but I would also say your ground cover is done very well also, what did you do there? My last backyard in New Mexico had several Sage bushes, never even thought of using the like this! :'(
Ray
« Reply #9 on: February 07, 2014, 10:18:04 PM »
Well done, Wolfgang! Great work.
« Reply #8 on: February 07, 2014, 03:08:25 PM »
Thanksa lot Wolfgang and Mark for these adresses  ;)
« Reply #7 on: February 07, 2014, 02:51:28 PM »
Thank you for the great addition Wolfgang!
This would also be a nice addition to the Knowledge base as well - I will add a link there back to your tutorial.
I have always been very impressed with your ACW dioramas, more impressed to find you created all of the trees by hand - really nice work.
Thanks for sharing!
P.S. I seem to recall Fredricus Rex sells quite a bit of nice diorama material.  Here in the US Walther's has quite a selection
http://www.walthers.com
They cater to RR builders but, the diorama materials are universal.
« Reply #6 on: February 07, 2014, 02:30:18 PM »
The fibers as well as the branches I have ordered from,
Sweetwater Scenery Products
Sweetwater Scenery
723 E 16th Street
Casper, WY 82601
Phone: (307) 265-2202
Web: www.sweetwaterscenery.com
Unfortunately, the contact through the Web page of the business since is canceled.
It would also interest me if the products are still vertieben.  :'( :'(
Some online Hänlern for model railways (USA) or eBay you have success.
If you are looking for products in this business since.
Maybe members in USA can ask some  ???
« Reply #5 on: February 07, 2014, 01:58:30 PM »
Hallo Wolfgang,
Yes as Eric, it's a fantastic topic  :) Thank you very much.
I have not read all your topic for the moment  ;) but could you say us the name of the society which sell the tree branch fibers ?
Thanks a lot for this advice.
« Reply #4 on: February 07, 2014, 01:13:47 PM »
Thank you Wolfgang for this very intereting and useful topic
« Reply #3 on: February 07, 2014, 01:12:42 PM »
– part 3
You will ask, what does this have to tuhen everything with flat figures.
Here you can see the answer.
The 24th Michigan brigade of the 1st Divison of the 1st Army Corps
July 1, 1863, the 24th Michigan under colonel Henry A. Marrow fought a desperade runningfight near the Lutheran Seminary at Gettysburg. After several color bearers were killed, the colonel himself took the flag until he was himself wounde at the head by a bullet.
« Reply #2 on: February 07, 2014, 01:10:20 PM »
– part 2
5.   Continue the process working your way from the inside and bottom of the armature to the outside and top. Continue until all desired branches have been covered with fiber. It is fine to leave some branches uncovered to represent a dead branch here and there [ Guests cannot view attachments ]
6.   Be sure that the fiber is not too dense. It is tempting to have a very 'full' looking tree at this point, but after the flock is applied it will be far too thick.
7.   Over a bag or in some other environment set up to catch the overshoot, spray the fiber with the hair spray until the spray beads up on the fiber. Be careful not to blow the fiber from the branches - try to spray in bursts instead of one constant stream. [ Guests cannot view attachments ] [ Guests cannot view attachments ]
8.   Carefully and slowly sprinkle on the flock. Darker flock can be applied to the bottom side of the fiber then apply some lighter to the top of the tree to give it a bit of a highlight. It is very important not to overdue the flock. You should still be able to see through the tree after the flock has been applied. [ Guests cannot view attachments ]
9.   Set the tree aside to dry and admire the creation! [ Guests cannot view attachments ]
10.   Tap off the extra flock into a container.
11.   Give the tree another light coat of hairspray to help keep the flock in place.
12.   Doing three or four trees at a time can speed up the process a bit and look nice all out together. [ Guests cannot view attachments ]
« Reply #1 on: February 07, 2014, 01:04:43 PM »
– part 1
It always begs the question, What trees can ausschauen a scenery diorama particularly well - flat figures trees or natural?
Here is a off to the natural product. [ Guests cannot view attachments ]
This tutorial will go through a step by step process to create realistic looking miniature trees for use in wargames, dioramas, and train layouts. These steps are very similar to those packaged in the Sweetwater Scenery poly fiber.
Materials
·   Sage brush
·   Poly fiber
·   AquaNet hair spray
·   Flock
·   Clothes pins or small clamps
·   Tweezers
·   Straight pins
·   Side cutters
Description of Materials
The trickiest part of making this type of tree is finding the correct materials. Sage brush can be found in several places including specialty hobby shops, online shops, and simply out in nature. Note that if you find and prepare the armatures yourself, they should be put in an oven and 'baked' for an hour or so at around 400 degrees to kill off any fungus, bugs, etc. The two vendors that I use are listed below in the links section and do an excellent job of preparing and selecting the highest quality armatures. Since I do not know of any sage growing in my area, I opted for the next easiest (unfortunately the most expensive) method of obtaining this material. A local hobby shop specializing in trains called Hobby Haven carries Sweetwater Scenery (a hobby company) sage brush for $2-3 per armature. The cost is quite a lot considering there is still a lot of work which needs to be done to get a tree out of the deal. I do, however, prefer the look of the finished product over anything that can be bought or of any of the other attempts at tree making I have done.
I also picked up some Sweetwater Poly Fiber since Hobby Haven happened to carry that as well. I prefer it over the Woodland Scenics since it is black vs green. The black seems to give the tree a bit more depth. The bag was under $3 and should make dozens if not hundreds of trees (depending on size - I've made seven trees thus far and haven't made a visible difference in the amount left in the bag).
The cheaper the hair spray the better (usually). What is basically needed is a spray adhesive. Real spray adhesives such as those from Elmers should work as well, but I haven't tried them. I use Unscented AquaNet hair spray which I picked up from K-Mart and have had good results.
As with my other terrain products I use Woodland Scenics flock to add 'leaves' to the trees. I am curious as to how much better (or worse) AMSI ground foam is, but I could not find a good source to get it from. I use Burnt Grass Fine Turf as the foundation for the trees with a touch of Green Grass Fine Turf to add a bit of highlight. Hobby Haven and Hobby Town USA both carry Woodland Scenics products for pretty much the same price. I buy from both.
A pair of clothes pins or a small clamp works well to hold the armature while working with it. When connecting two clothes pins in an L fashion they also serve as a convenient stand to keep the tree upright when drying.  Reference some of the photos below for a pictorial description of what I'm trying to say.
A pair of tweezers helps out a lot when trying to pull the fibers over the branchs.
At the base of each tree I poke a straight pin in to help hold the tree in place when 'planted' on the layout. After the pin is stuck in the end is clipped off with a pair of side cutters.  Sweetwater also offers more 'finished' armatures which include a pin already in the base of the armature.  I have yet to see a 'finished' version of the sage since the hobby shop had only 'bulk' in the smaller sizes - I believe other finishing touches are added to the armature in addition to the pin.  In a future revision of this tutorial I will attempt to purchase a 'finished' armature and compare and contrast it with the 'bulk' armatures.
A simple pair of side cutters or anything else which will cut a straight pin will work just fine.
Sagebrush Tree Construction Steps
1.   Prepare the armature. Stick a straight pin into the base of the tree to add stability when 'planted'. Clip the pin head off after inserting the pin. [ Guests cannot view attachments ]
2.   Pull a very small amount of poly fiber from the bag. About 1/2x1/2x1/4 inch section will do. The sections do not and should not be exactly the same size - just keep them fairly small. [ Guests cannot view attachments ] [ Guests cannot view attachments ]
3.   Pull the piece apart so it is the density of a three dimensional spider web. Be sure to pull the fiber out in all three dimensions rather than making 'sheets'. [ Guests cannot view attachments ]
4.   Starting at the bottom of the armature, place the fiber on a single branch of the armature. Try not to span multiple branches - each branch should get its own fiber. Note that I have done three separate branches in this photo: [ Guests cannot view attachments ]
